Ignition key
tmcalester
PostPosted: Mon Aug 06, 2018 8:45 pm    Post subject: Ignition key Reply with quote
Does anyone know where I can get an ignition key for a 1983 Lagonda? I tried the local key shop and they did not have a blank that matched the existing key
PostPosted: Tue Aug 07, 2018 11:59 am    Post subject: Reply with quote
I made a copy several years ago. I'll check the brand/model.
tmcalester
PostPosted: Tue Aug 07, 2018 5:42 pm    Post subject: Lagonda Ignition key Reply with quote
Thanks
PostPosted: Sun Aug 12, 2018 8:34 am    Post subject: Reply with quote
https://www.keyprof.com in Germany and Holland
PostPosted: Fri Aug 17, 2018 11:13 pm    Post subject: Lagonda ignition key Reply with quote
Assuming that your Lagonda ignition switch uses the same key blank as my 1988 Lag, the key blank you need is a Silca YM27P. If you need a copy of the cut sheet from the Silca catalog, send me a PM and I will forward it to you. The cut sheet lists dimensions and cross-reference numbers as well.
If you can't find the key blank locally, you may wish to contact www.steveslockshop.com/british.html.
Hope this helps...
Living on the [w]edge...
