tmcalester
Posted: Mon Aug 06, 2018 8:45 pm Post subject: Ignition key |
Does anyone know where I can get an ignition key for a 1983 Lagonda? I tried the local key shop and they did not have a blank that matched the existing key |
tmcalester
Posted: Tue Aug 07, 2018 5:42 pm Post subject: Lagonda Ignition key |
Thanks |
Hawke
Joined: 02 Jul 2011 Posts: 29 Location: Oconomowoc, Wisconsin, USA
Posted: Fri Aug 17, 2018 11:13 pm Post subject: Lagonda ignition key |
Assuming that your Lagonda ignition switch uses the same key blank as my 1988 Lag, the key blank you need is a Silca YM27P. If you need a copy of the cut sheet from the Silca catalog, send me a PM and I will forward it to you. The cut sheet lists dimensions and cross-reference numbers as well.
If you can't find the key blank locally, you may wish to contact www.steveslockshop.com/british.html.
Hope this helps... _________________ Living on the [w]edge... |
