13316
Posted: Sun Nov 29, 2015 5:43 pm Post subject: slow charging |
My Lagonda 1984 is slow charging. When I first start the car it takes a few minutes before it charges correctly, so it first the turning signal, window, etc. do not work until the alternator charges correctly. Is the alternator going bad?
Thank you for your help. |
Posted: Wed Dec 02, 2015 7:52 am Post subject: |
There seems to be a problem.
Everything should work nearly immediately. |
Posted: Wed Dec 02, 2015 9:26 am Post subject: |
Sounds like a fault.
Alternator or more likely the alternator regulator. |
Posted: Wed Dec 02, 2015 9:37 am Post subject: |
jonc wrote: | Sounds like a fault.
I confused between ' not working' and 'working slowly'; My alternator has been checked and repaired, but the popup light and windows are working slowly when charge is less than 11 V _________________ Welcome to Paradise ! (FRONT 242)
