AML_Canada
Posted: Sat May 05, 2012 7:10 am Post subject: How do you adjust the valve clearances? |
Could someone direct me how to adjust (and specs) the valve clearances?
When I had the valve covers off, I do not remember seeing any way to adjust them?
Thank you.
Regards,
Harjeet |
Posted: Sat May 05, 2012 8:35 am Post subject: |
The adjustment is done with shims under the followers. AML supply shims in different thicknesses which are used to set the clearances.
Basically, you measure and record all clearances, then you remove all the shims and record what thicknesses are in place. Then you work out what you actually need at each location. Then you work out which you have and which you need to buy.
Posted: Sat May 05, 2012 10:06 am Post subject: |
Pay attention the clearances are different from US cars to 'normal' cars. _________________ Welcome to Paradise ! (FRONT 242)
1974gt4
Posted: Sun Sep 08, 2013 3:22 am Post subject: |
so the USA cars are ab-normal?
Posted: Mon Sep 09, 2013 10:10 am Post subject: |
Not at all, but US cars are depoluted and the compression ratio is different from all other cars ( I wrongly said 'normal' cars...) _________________ Welcome to Paradise ! (FRONT 242)
