Posted: Wed Mar 29, 2017 10:36 am Post subject: not so technical: boot trim |
Is the trim that sits on the inside of the bootlid directly secured to the bootlid or is the trim glued to a wooden panel that is attached to the bootlid (like for instance the boot rear panel mounted against the fuel tank).
I'm referring to the trim that covers the horizontal part of the bootlid, not the rear light cluster covers.
Johan |
Posted: Thu Mar 30, 2017 2:56 pm Post subject: |
Trim is glued on wood, secured to inner frame of bootlid with screws direct through it and partially covered by stainless steel L-shaped liner.(screwed to side flange of inner frame.
H |
Posted: Thu Mar 30, 2017 6:39 pm Post subject: |
Dank! |
