steelydave39
Joined: 11 Mar 2012 Posts: 40 Location: New York City, USA
Posted: Mon Oct 10, 2016 12:41 am Post subject: Door problem |
Suddenly my passenger front door will not open. The lock is working, as the handle does unlock the door, but the lock is not fully unlatching. How can I get the door open? I believe the interior door panel cannot be removed without opening the door, so how do I access the issue? |
Posted: Sun Oct 16, 2016 6:05 pm Post subject: |
You can (just) get the door panel off. - I've had to do it before.
Remove all the fixings as per normal, whilst fiddly due to the angles, it is still achievable.
The door panel is made of glass fibre and will flex.
It'll make some noises but will just pull off and away, I needed to do it on 13008 due to the doors being jammed and one other in the past too.
Pull it smoothly, don't snatch it, glass fibre is very forgiving to a slowly changing load but brittle if manipulated quickly.
