Posted: Fri Jun 20, 2008 8:05 pm Post subject: Which motor oil |
Which motor oil do you recommend?
20W-50?
/M |
Posted: Sat Jun 21, 2008 3:03 pm Post subject: |
I use Castrol Classic 20W-50 recommended by Roos Engineering.
What is your cars VIN Number, where are you from and finally will you attend our meeting in Lindau?
Zoran Mitrovic
13417 |
Posted: Mon Jun 23, 2008 8:18 pm Post subject: |
Hi Zoran, thanks for the help.
I will be in Lindau and the VIN is 13063
/Martin |
blacky
Posted: Mon Jun 23, 2008 9:46 pm Post subject: |
I have bought my Lagonda from a U.S. New England Aston Martin dealer. It had its last oil change done with 20W50 oil. Runs great, no problems. I wondered because in Germany usually 15W40 is used. But as Lagondas tend to run at high temperatures, and as they lack sealings at the valve shafts, I probably will continue to use this oil.
But I am also interested in other opinions.
S. Schneider / Germany
#13473 |
Joined: 02 Dec 2007 Posts: 38 Location: New York, USA
Posted: Tue Jun 24, 2008 1:05 am Post subject: |
As per the dealer here, I use 20W-50 Mobile 1 synthetic. |
billmorrow
Joined: 16 Jan 2008 Posts: 38 Location: Eatonton, GA - USA - whats YOUR location..??
Posted: Tue Jun 24, 2008 6:42 am Post subject: |
i have used mobil 1 5/40 (i think)..
i really don't care if a little seeps out, i want the oil circulating fast when i start the car..
in fact, it sits so long between starts, i always let it crank for 10 seconds to be sure all engine surfaces are oiled before i pull the choke out and it fires up.. _________________ Bill Morrow, kept by parrots
Sysop - forum.thinkpads.com
She was not what you would call refined.
She was not what you would call unrefined.
She was the type of person who kept a parrot.
~~Mark Twain~~ |
Posted: Tue Jun 24, 2008 7:38 pm Post subject: |
When my car goes to WS they put Mobil 1 in. I assume 20/50. |
Posted: Tue Jun 24, 2008 9:36 pm Post subject: |
After the engine rebuild I filled it up with 5w40\full synthetic longlife.Lots of iolpressure when hot and no annual refills.
