Posted: Mon May 02, 2011 11:47 am Post subject: 1981/2 UK RHD Wiring Diagram Errata |
I am in the process of correcting / removing the wiring butchery from my car, and use the 1981/82 wiring diagram I have as a reference. It is the easiest to use since it is annotated with the wire numbers on the diagram. It is actually more ‘loom schematic’ than wiring diagram, but is nevertheless very useful.
In the process of understanding the wiring I have found a number of errors and thought this was the best place to record them. As I find more in future, I will post them here. The first number is the item reference, as found either on the diagram or in the workshop manual, other numbers are wire numbers.
22 - washer pump - wires 41 / 42 - diagram shows 41 (light green/black) goes to fan relays - (feed). wiper stalk (110) shows 41 also - these should be 42 (green).
43 - starter motor - solenoid wire is 51 (incorrectly labelled 142)
95 - Aircon loom, snap connector 95 (left one) wires are: 173, 174, 175 and 157 provides feed (157 is obscured/incorrect)
108 - indicator flasher unit, is this 355? Also listed on LH seat motor. I think the seat is wrong. 355 is fed from a join to 370, also not shown.
112 - dash warning lamp connectors - far left wire is 370 (incorrectly labelled 307)
123 - auto-lock relay - yes, that is a break between the coil and contact (ground) not a repro error!
129 - RH snap connectors, forth connector, wires are 291, 322, 323, 324, 325 (last one is incorrectly labelled 324)
129 - RH snap connectors, fifth connector, wires are 290, 315, 326, 327, 328 (326 is incorrectly labelled 236) |
Posted: Wed Jun 27, 2012 5:26 pm Post subject: |
39 - Under bonnet fuse box, fuse 10 has left wire 100, right wire 86 (incorrectly labelled 106) |
Posted: Sun Jul 05, 2015 11:03 am Post subject: |
162 - LH fuel flap relay - wires 411 and 216 have their numbering swapped
163 - RH fuel flap relay - wires 407 and 222 have their numbering swapped |
Posted: Wed Sep 16, 2015 6:58 pm Post subject: |
117 - wire 40 should be 401, going to fuse 9 on the internal fuse box. |
Posted: Mon Sep 21, 2015 1:52 pm Post subject: |
99 - screen demist microswitch - wires 178 and 173 are the wrong way round.
70 - aircon harness plug - wires 77 and 157 are connected together.
101 - A post max aircon (blue) switch is missing a connection to 157 (sensor string into programmer) and a ground. |
Posted: Sat Nov 07, 2015 6:13 pm Post subject: |
118 - Instrument panel connector, pin 25 should be 367 (EIO)
118 - pins 13 and 14 - wires are the wrong way round - 13 is 388 (CLOCK), 14 is 390 (SET) |
