Lagonda name plate on wheels
PostPosted: Sat Nov 08, 2014 8:56 pm    Post subject: Lagonda name plate on wheels Reply with quote
In the centre of the wheels there is the name plate "Lagonda".
How is this fixed on the wheel?
On one wheel it came off today, and beneath was just something like grease?!
PostPosted: Sun Nov 09, 2014 3:48 pm    Post subject: Reply with quote
I am assuming pepperpots?
It clips into place. There is an outer ring which is black anodised aluminium which holds the disk with logo into place. I think it is this part (although they don't mention the material so this might be a later plastic version):
http://www.sngbarratt.com/AlternativeItemDetails.aspx?id=f7f92489-f526-401b-82b4-e9f09c1728f0
PostPosted: Sun Nov 09, 2014 4:58 pm    Post subject: Reply with quote
It is not the pepperpots. It is the disc, I think second version.
The part which has come loose hs no clips is just "plane". May be the clips have broken?
PostPosted: Sun Nov 09, 2014 5:25 pm    Post subject: Reply with quote
The CRT cars have wheels with a large central disc that covers the wheel nuts.
In the centre of this is the Lagonda badge.
This badge is a plastic disc that simply glues into place into a shoulder milled into the central raised (black covered) rim.
This aluminium rim is just glued into the centre of the wheel disc but is also machined to be a very tight fit.
The black coloured ring corrodes quite badly and will just force the badge disc out as it expands.
The grease that you see is, particularly if it is a front wheel most likely sprayed out from the wheel hub.
You will need to clean the central ring thoroughly and carefully and then glue a new (or old if you still have it) disc back into place.
PostPosted: Sun Nov 09, 2014 6:18 pm    Post subject: Reply with quote
David, that is what it looks like! I have seen no corrosion, and yes, it is the front right. And yes I stll have it!
What glue would you recommend?
Thank you!
PostPosted: Sun Nov 09, 2014 9:34 pm    Post subject: Reply with quote
Thank you!
Building silicone !
PostPosted: Mon Nov 10, 2014 8:13 am    Post subject: Reply with quote
We use a two pack epoxy glue and bond it from the rear as this way it reduces the risk of the glue spilling over the outer edge and being visible.
PostPosted: Mon Nov 10, 2014 11:34 am    Post subject: Reply with quote
2 components glue or silicone ( easier findable ), the result is the same.
