Posted: Mon Feb 25, 2013 5:01 pm Post subject: 13049 |
(I have moved this from owners cars)
It has been a restoration project since I bought it in 1995!
Bodywork Spraytec 2007
Rebuild of rear brake callipers Works Service 2009
Service airconditioning, new vacuum hoses, service dashboard, etc at David Marks 2010
August 2011 Robert attending to faulty water temperature gauge
Posted: Mon Feb 25, 2013 5:04 pm Post subject: |
2012 my Annus horribilis.
230812 Early in Folkestone, happy and ready to go to Salzburg.
After a momentary lapse of concentration.... I am usually obsessively cautious! The damage.
At the halfway stage, Oberwesel (Hotel Schoenburg), I am experiencing overheating & ignition problems. David works on the fans.
240812 We soldier on and reach the hotel near Salzburg but I am still having engine problems. 250812 The car is recovered to Peter Mueller's place in Teisendorf for review of ignition. Peter is Michael von Aretin's engineer.
100912 Car is recovered by AA/Onetime arriving at David's 120912.
We assess damage again. A new bumper is required.
Meanwhile David services the car. Radiator is reconditioned. New fans & fan relays. New HT leads, distributor. New set of airconditioning pipes built and installed.
191012 Car at AM WS and the extent of corrosion is exposed.
121212 Car taken back to David's by Konig & more horror is revealed.
110113 Preparation starts.
Posted: Mon Feb 25, 2013 5:13 pm Post subject: |
160113 Dismantled and cut. Oil coolers and carrier trays removed as well.
More or less finalised preparation, apart from final cutting to ensure the new panels fit. The welder now has to make up the new panels as required and come back to start fitting and welding. |
Posted: Mon Feb 25, 2013 5:21 pm Post subject: |
Jonathan 18 Jan 2013 12:38 pm
Quote:
Really strange that only some cars rust there... Vincent 130113
Water will get behind the bumper from above. The bumper sits just below the metal lip of the outer front panel. Driving the car in the rain will force water into this gap if it is not properly sealed (and I bet many aren't sealed propery - including both of mine). Once it eats through the outer panel, it will make a start on the inner one, and the sides.
Out of all of the design and construction detail of the Lagonda, I think the front is the worst. It takes the greatest battering from the elements, and yet it is the worst protected. Just above the bumper is the exposed steel edge of the front panel, above this the lamp glasses need sealant to their edges where they fit against a steel surround, and yet must be removed for bulb changes. And above this the bonnet landing panel with another exposed steel edge and a rubber seal on top of it - somewhere else for the water to be forced into. Then the popups with their gaps allowing water to get in to the areas with the ignition and other electrics when the car is standing. Compare this to the V8 with a one-piece aluminium front. Keep your cars out of the wet, or make sure all the front components are all sealed together properly.
On top of this, I think there should have been active air circulation behind the lamp glasses. The P38A Range Rover has this through the headlamp and driving lamps (so when you go wading they drain and clear). I may fit this some day - its just a regulated vacuum feed off the engine.
Roger - at least you will know you have a better car when the work is done -better rust-proofed than it left the factory. It's now a 'restoration' and so you can start your own thread in that forum. |
Posted: Tue Dec 16, 2014 10:24 am Post subject: |
30th January 2013 Work restarted and the panel work was made to fit before welding. |
Posted: Tue Dec 16, 2014 11:09 am Post subject: |
January 2013 Bumper comparisons. Sample with filler. 13049 v 13150
Posted: Tue Dec 16, 2014 11:16 am Post subject: |
7th February 2013 Coming together (using a borrowed bumper)
Posted: Tue Dec 16, 2014 11:20 am Post subject: |
February 2013 Welding
Posted: Tue Dec 16, 2014 11:26 am Post subject: |
13th February 2013 Additional work found on front wing
Posted: Tue Dec 16, 2014 11:47 am Post subject: |
April 2013 Bumper moulds
Posted: Tue Dec 16, 2014 11:54 am Post subject: |
April 2013 Coming together, lights in
Posted: Tue Dec 16, 2014 11:59 am Post subject: |
14th April 2013 Nearly there
Posted: Tue Dec 16, 2014 12:03 pm Post subject: |
New light glass
Posted: Tue Dec 16, 2014 12:08 pm Post subject: |
18th April 2013 All done and ready to go!
Posted: Tue Dec 16, 2014 12:20 pm Post subject: |
23rd January 2014 Lights, fans, washer/wipers
