Brake Light Switch
AML_Canada
PostPosted: Fri Jun 15, 2012 6:42 am    Post subject: Brake Light Switch Reply with quote
Anyone sourced a replacement for the brake light switch mounted up high under the dash near the brake pedal pivot. It has 4 connections. One pair is normally connected and the other pair normally disconnected. When applied the connections become opposite.
PostPosted: Fri Jun 15, 2012 9:09 am    Post subject: Reply with quote
Does it have any markings on it? As far as I can tell, it is not a Lucas item, and the AM V8 had a pressure switch in the brake like for the lights.
There will be two sets of contacts because one set is needed for the cruise control cancel, something not on the V8.
I wonder if something like this would be a better replacement: http://www.flyingspares.com/shop/rolls-royce-spirit-spur-bentley-turbo-mulsanne/electrical/senders-transmitters/brake-switches/brake-light-cruise-control-switch-ud72267.html
The use of off-the-shelf microswitches would make it reliable, but also easy to fix.
AML_Canada
PostPosted: Fri Jun 15, 2012 8:12 pm    Post subject: Reply with quote
Not a Lucas switch; did note the info down somewhere... Will post when I find it....
However, the RR dual microswitch you suggested is a FAR better replacement. I was actually thinking to fabricate something exactly like that!
Thank You! Smile
PostPosted: Fri Jun 15, 2012 8:18 pm    Post subject: Reply with quote
great - let us know how you get on. I would still like to know the make of the original switch - maybe we can track it down.
PostPosted: Sat Jun 16, 2012 9:17 am    Post subject: Reply with quote
This looks like the nearest equivalent:
It is made by Standard Motor Products as an aftermarket replacement. Part no is SLS110. Alternative manufacturer: Sorensen SW-138. Compatibility seems to be listed as:
71-85 BUICK
70-85 CADILLAC
67-89 CHEVY
68-85 OLDSMOBILE
From different manufacturers I have seen it in black, grey and white plastic.
These are ten dollar commodity parts. Personally, I would use the Rolls-Royce alternative if I had to replace one.
