Posted: Thu Dec 08, 2011 5:45 pm Post subject: Dismantling 13169 |
We are now busy to dimantle 13169 LHD.
Do you need something, just let me know. I'll check if available and quote.
What is already sold ( or not usable ):
carpets, bumpers, bonnet, front lights, rear and front screen, left front wing, carburators, exhaust line ( but I have parts -manifolds, rear exhausts- for US emission cars )...
Prices made to sell parts and not to stay with.
The complete engine is away for a revision/rebuild and will be available next year. _________________ Welcome to Paradise ! (FRONT 242)
Joined: 03 Jun 2008 Posts: 284 Location: Leigh-on-Sea, United Kingdom
Posted: Fri Dec 09, 2011 8:45 am Post subject: |
Hi Vincent
I do not suppose by any slim chance the car has the heated front headlamp glasses ? If so then I would like to buy them.
There is also the possibility I may need several cruise control bits for my car but I would need David Marks to confirm what they might be. He is scheduled to have my car January / February next year so if you could keep any of those parts in mind for me I would appreciate it very much.
My car is also going to have the Anti Roll Bar Drop Links overhauled and a Slack Differential investigated & put right. In my total mechanical ignorance, I have absolutely no idea what any of this means or if the various parts required are readily available new. If the components are not available then I would ask David to contact you to see if any bits from your car would suit.
Thank you.
Lagonda 13302 |
Posted: Fri Dec 09, 2011 1:54 pm Post subject: |
Anti roll bar links changed at 13284, but I imagine David is just fitting new rubbers anyway.
Vincent - you still have my list from the summer?
Jonathan. |
Posted: Fri Dec 09, 2011 2:33 pm Post subject: |
Thanks for the piece of info Jonathon.
David recommended earlier in the year that the bushes and/or assembly will need to be overhauled during the coming winter period. |
Posted: Sat Dec 10, 2011 8:10 am Post subject: |
jonc wrote: | Anti roll bar links changed at 13284, but I imagine David is just fitting new rubbers anyway.
Jonathan. |
The price of new rubbers doesn't justify to take them off 13169.
Jonathan, I update the list from time to time. _________________ Welcome to Paradise ! (FRONT 242)
Posted: Sat Dec 10, 2011 8:14 am Post subject: |
Keith wrote: | Hi Vincent
Thank you.
Lagonda 13302 |
The heated glasses burned with the car. For the rest, ask David. He comes to see my car end of this year.
Thank you ! _________________ Welcome to Paradise ! (FRONT 242)
Rodolphe
Posted: Sat Dec 10, 2011 12:22 pm Post subject: |
Salut Vincent,
Je suis intéressé par les chromes sous les deux ailes arrière en priorité et ceux des portes et aile avant gauche puis par les enjoliveurs de roue
Merci beaucoup  |
Posted: Sat Dec 10, 2011 12:38 pm Post subject: |
Rodolphe wrote: | Salut Vincent,
Merci beaucoup  |
Tout ok sauf aile av g ( attention, les dimensions ne sont pas identiques d'une voiture à l'autre ); que veux tu faire avec des couvercles de casserole en inox alors que ton auto est en pepperpot ?  _________________ Welcome to Paradise ! (FRONT 242)
Rodolphe
Posted: Sat Dec 10, 2011 2:29 pm Post subject: |
J'ai dans l'idée le jour ou l'envie m'en prendra de changer le look de la voiture sans réels modifications.
Concernant mes chromes ils sont abimés à l'arrière Ainsi que l'un de mes feu arrière.
Je t'ai envoyé un petit mail avec mon numéro de Tel  |
mikke
Posted: Wed Dec 28, 2011 7:32 am Post subject: |
Hello,vicent
can you sell me the contactor box? (i dont know how say in english)it has 4 below the fuses ,near the horn and behind the rear seat.
my lights up but not dowm,when i log out the lights.
i think is this part.
best regards
Miguel. |
mikke
Posted: Wed Dec 28, 2011 7:33 am Post subject: |
there are transparents |
Posted: Wed Dec 28, 2011 8:41 am Post subject: |
I think you mean the latching relays - the four under the engine bay fuse box are for side, head, fog and spot lights.
There is one at the front right for the horns and on earlier cars, one behind the rear seat for the heated rear screen.
To prove it is the relay, it may be worth using the heated screen one to test the headlight one but do take note of the connections on each relay!
The heated screen one has the most chance of being OK as it is not used often and is housed away from heat and water ingress.
Posted: Wed Dec 28, 2011 7:03 pm Post subject: |
mikke wrote: | there are transparents |
I just have the one behind the rear seats. The ones in the engine bay are burned...  _________________ Welcome to Paradise ! (FRONT 242)
Posted: Tue Jan 31, 2012 6:30 pm Post subject: |
Most parts of the car are now away ( or kept for my Lags ).
If you have any enquiry, please send an email at
vanquish@skynet.be
and I'll say if it's available or not, and quote.
Thanks _________________ Welcome to Paradise ! (FRONT 242)
