Posted: Thu Nov 25, 2010 9:42 am Post subject: Exhaust manifolds |
Thought I would post this Q & A
From an owner
> I really need 2 exhaust manifolds.
> I fancied having a set manufactured out of
> stainless with a pipe bender – free flow – but the ones that exist have
> screws in for each cylinder to check the gas emitted from the engine, I
> believe, so I don’t know if I could do away with the screws? Do you have any knowledge of this?
Answer from David
Yes, you can do away with the screws if you wish.
In theory you would use the take offs to measure each cylinder combustion but in practice, I doubt if any of them would undo after even a year or so. I think only those people setting up an engine for racing or being very particular for some reason would try to do things that way - we use vacuum gauges and gas analysers to set the carbs.
We had some made up in stainless so should not corrode.
There are different manifolds for different applications so if ordering from
AM, ensure the correct VIN is noted.
