relay location
PostPosted: Sun Jun 25, 2017 5:09 pm    Post subject: relay location Reply with quote
Does anybody have a diagram that outlines which relay does what for the relays located under the fuse boxes under the bonnet?
There are 3 banks of normal relays and 4 latching relays but can't make out from the wiring broadsheet which one is which.
DonaldNZ
PostPosted: Wed Mar 18, 2020 2:23 am    Post subject: Reply with quote
You can work it out and I may be able to help.
In my experience,
battery unfused [yes so it will melt if fault enough ] = [usually] brown
battery fused = purple
ignition unfused [see above] =white
ignition fused = green
If you post the wiring colours of each relay, I may be able to work it out.
so
85 =
86 =
30 =
87 =
87A =
