Sender units
tmcalester
PostPosted: Tue Jun 20, 2017 7:38 pm    Post subject: Sender units Reply with quote
The dash on my 1983 shows a figure 1 for both the water temperature and oil temperature. New sender units were installed in 2013. Is there a way to 'test' the sender units to see if they are defective?
PostPosted: Wed Jun 21, 2017 9:34 am    Post subject: Reply with quote
If you remove the wires from the senders, see if the display changes at all.
Then see if the display changes if you ground the wires to the senders.
If there is little or no change this implies a problem with either the wiring to the display pack or the pack itself.
If the latter, this gets complicated but for the former, if you remove the instrument pack and check the respective wires for continuity from the senders to the I/P you can easily identify if there is a wiring issue to the pack or an internal problem with the display unit.
Hope this helps
