steelydave39
Joined: 11 Mar 2012 Posts: 40 Location: New York City, USA
Posted: Mon Aug 29, 2016 2:06 am Post subject: Brake lights |
My 1985's brake lights ceased working today, also causing the brake interrupt of cruise control to fail. Two questions... 1. Assuming its not the brake light switch, are these typical parallel wired brake lights, or serial like Christmas lights are, meaning if one bulb goes out, they all go out? 2. If its a fuse, there must be another one besides the one in the center console. Very odd if that the only one, as it appears the one fuse addresses about 10 different things. Is there another fuse, and if so, where? If its in the engine compartment with the odometer, please specify which one it is. Any thoughts are appreciated |
Posted: Mon Aug 29, 2016 9:44 am Post subject: Re: Brake lights |
steelydave39 wrote: | My 1985's brake lights ceased working today, also causing the brake interrupt of cruise control to fail. Two questions... 1. Assuming its not the brake light switch, are these typical parallel wired brake lights, or serial like Christmas lights are, meaning if one bulb goes out, they all go out? 2. If its a fuse, there must be another one besides the one in the center console. Very odd if that the only one, as it appears the one fuse addresses about 10 different things. Is there another fuse, and if so, where? If its in the engine compartment with the odometer, please specify which one it is. Any thoughts are appreciated |
If it's not the switch, check the wiring first...or the two bulbs ! _________________ Welcome to Paradise ! (FRONT 242)
