slow charging
13316
PostPosted: Sun Nov 29, 2015 5:43 pm    Post subject: slow charging Reply with quote
My Lagonda 1984 is slow charging. When I first start the car it takes a few minutes before it charges correctly, so it first the turning signal, window, etc. do not work until the alternator charges correctly. Is the alternator going bad?
Thank you for your help.
PostPosted: Tue Dec 01, 2015 2:40 pm    Post subject: Reply with quote
I should say no, it's so on mine too...
PostPosted: Wed Dec 02, 2015 7:52 am    Post subject: Reply with quote
There seems to be a problem.
Everything should work nearly immediately.
PostPosted: Wed Dec 02, 2015 9:26 am    Post subject: Reply with quote
Sounds like a fault.
Alternator or more likely the alternator regulator.
PostPosted: Wed Dec 02, 2015 9:37 am    Post subject: Reply with quote
I confused between ' not working' and 'working slowly'; My alternator has been checked and repaired, but the popup light and windows are working slowly when charge is less than 11 V
