Posted: Wed Aug 06, 2008 7:04 pm Post subject: Vacuum Hoses |
Does anyone have any book of information about the running of the vacuum hoses that operate the heater valves (both water & air routing)?
Please respond to Harry Kielstra (13007) on info@autodakar.nl |
Posted: Mon Aug 11, 2008 7:13 pm Post subject: |
Is it the system with air pumps on depolluted cars ?
If yes I can fax it when back from holidays. _________________ Welcome to Paradise ! (FRONT 242)
Posted: Tue Aug 12, 2008 3:51 pm Post subject: |
What I need is the routing from the small hoses that operate the the heater valve and the flaps from defroster/ foot well/side vents.
they come from the heater switch on the dashboard.
Main vacuum is picked up somewhere in the engine compartment but some hoses are broken and parts missing.
Joined: 02 Dec 2007 Posts: 38 Location: New York, USA
Posted: Thu Aug 28, 2008 8:18 pm Post subject: |
i've been using fish tank air hose as a replacement. You might also check out medical supply stores for oxygen tank hose. |
billmorrow
Joined: 16 Jan 2008 Posts: 38 Location: Eatonton, GA - USA - whats YOUR location..??
Posted: Mon Sep 01, 2008 8:28 pm Post subject: |
your hoses will need to be stiff enough so as NOT to collapse when vacuum is applied..
before jeff was murdered in chicago (must resist to make nasty comments about chicago, here) i removed from my parts car, the entire vacuum hose assembly from under the dash and labeled each hose as to where it went..
then i photographed it and emailed that photo to jeff..
the result of all this typing is that i have the picture someplace and i STILL HAVE the vacuum hoses and so forth in my garage..
so i can make a new picture and or find the old one if that will help..
also, other small parts keep turning up..
please note:
I sold the parts car so most of it is gone.. _________________ Bill Morrow, kept by parrots
Sysop - forum.thinkpads.com
She was not what you would call refined.
She was not what you would call unrefined.
She was the type of person who kept a parrot.
~~Mark Twain~~ |
Posted: Tue Sep 02, 2008 4:36 pm Post subject: |
Bill, if you would do so I would be most happy and check/reconnect the system .
You can send it by personal message it you can
Greetz Harry 007 |
billmorrow
Posted: Wed Sep 03, 2008 8:26 am Post subject: |
what is your email address..
i will email them.. _________________ Bill Morrow, kept by parrots
~~Mark Twain~~ |
Posted: Thu Sep 04, 2008 8:41 pm Post subject: |
I have some documentation on the AC system if that would be useful including vac hose routes |
billmorrow
Posted: Mon Sep 08, 2008 6:13 am Post subject: |
i already sent the hose pix to: info@autodakar.nl
did you get them..? _________________ Bill Morrow, kept by parrots
~~Mark Twain~~ |
Posted: Tue Sep 09, 2008 4:37 pm Post subject: |
To Bill, there here, just decyphering them this weekend
Thanks Harry |
