Disconnecting cables to front doors
RogerS
PostPosted: Sun Jul 22, 2018 2:25 am    Post subject: Disconnecting cables to front doors Reply with quote
I have to remove the front doors to 013294 in order for the panel beater to get to the edge of the front body panel. i cant see an easy way to unclip and disconect the electrical cables connection. Is there one or do you have to reterminate the connection block? Thank you Roger.
PostPosted: Sun Jul 22, 2018 12:15 pm    Post subject: Reply with quote
Yes, you will need to remove the wires from the terminal blocks and re assemble afterwards.
Take careful notes and pictures and disconnect the battery!
RogerS
PostPosted: Wed Jul 25, 2018 7:57 pm    Post subject: Reply with quote
Thank you David i suspected that might be the case.
It looks like i need to replace the four rubber mounting blocks for the gearbox and engine, are they specific to AM? RogerS
PostPosted: Thu Jul 26, 2018 7:30 am    Post subject: Reply with quote
For engine mounts we use Land rovers e.g. Discovery 1 or RRClassic V8.About 2 pounds in UK. Transmount rubbers custombuilt at zilenz.nl (trillingdemper type 1, around 7 euros a piece) Margie
