13406
Goto page 1, 2  Next
Post new topic   Reply to topic    LagondaNet Forum Index -> Lagonda Restorations
feniks
PostPosted: Thu May 19, 2016 9:29 pm    Post subject: 13406 Reply with quote
406 being a very fine 10-feet car
After close inspection a few rust spots were found that needed welding.
Before starting this the dash and it's electronics were removed for not to be damaged
See what was found when car is being dismantled.
feniks
PostPosted: Thu May 19, 2016 9:56 pm    Post subject: Reply with quote
Starting with RH C-post.
As this is all beyond repair it is completely rebuilt in new sheet metal
Trial fitting with outer fender
Now for inner and outer sill
Trial fitting of outer sill
Now concentrating on inner sill and floor
Score sofar
feniks
PostPosted: Thu May 19, 2016 10:02 pm    Post subject: Reply with quote
As car will get bare metal respray all body panels were send to the paint shop.
There was found one of the doors lost some of it's underside.
New sheet metal is formed to fill in cut out bottom.
Dimitri
PostPosted: Tue May 24, 2016 8:05 pm    Post subject: Reply with quote
Keep up the good work Mr Feniks ! Smile
View user's profile Send private message AIM Address
feniks
PostPosted: Tue May 24, 2016 8:10 pm    Post subject: Reply with quote
Bottom of door is made from scratch using basic tools, hammer and
wooden template
Now ready for bare metal like the rest of the panels
feniks
PostPosted: Tue May 24, 2016 8:14 pm    Post subject: Reply with quote
Rust on a Lagonda can be funny, outer halfs of floors both in bad state, but
prone to rust front bar is tops.
PostPosted: Tue May 24, 2016 8:34 pm    Post subject: Reply with quote
Now where have I seen this before? Good job!
Dimitri
PostPosted: Tue May 24, 2016 8:37 pm    Post subject: Reply with quote
At least it wasn't crushed in the Channel Tunnel... Twisted Evil
feniks
PostPosted: Sun Jun 12, 2016 9:20 pm    Post subject: Reply with quote
O K next is the left side, supposed to be the better side as it had been done before. Turns out to Bill Towns meet Fred Flintstone
To start with solid metal means grind back to where there is no rust!
Back in goes centre section of sill, as you can see all posts are braced together to avoid distortions
Next is floor section followed by inner sill
And outer sill to keep it simple
Last in are brace plates and seat supports.
To be followed by finishing C-post as per right side, grinding all welds, sealing them and put on several rust proofing before it is of for paint
Dimitri
PostPosted: Wed Jun 15, 2016 9:52 am    Post subject: Reply with quote
It would probably be a good idea to Dinitrol the whole thing at this point to avoid a return ticket in 10 years' time...
PostPosted: Wed Jun 22, 2016 4:38 am    Post subject: Reply with quote
Good thing but Bodyshoppers would kill you is my guess ,after paint might be a better idea Very Happy
feniks
PostPosted: Mon Jun 27, 2016 8:44 pm    Post subject: Reply with quote
Finished almost ready for paint
last piece of metal work ,putting the fender part back in
While car is of for paint now a little detail to be fixed, the backplate / cover of rear doorlatch.
Slightly altered from original, bottom side now at a 45 degrees angle so there will not again be trapped for ever moisture in it
feniks
PostPosted: Mon Jun 27, 2016 8:48 pm    Post subject: Reply with quote
406 at paint shop completely bare-metaled
And parts primered
Dimitri
PostPosted: Tue Jun 28, 2016 10:03 pm    Post subject: Reply with quote
we want pics !
feniks
PostPosted: Tue Jul 05, 2016 9:05 pm    Post subject: Reply with quote
Not much to be seen on drying of paint but this is the second layer of filler.
At the moment the paint crew is busy flattening it prior to paint end of week.
Post new topic   Reply to topic    LagondaNet Forum Index -> Lagonda Restorations All times are GMT
Goto page 1, 2  Next
Page 1 of 2
