Podcast - Fast Lane cars - Lagonda
Goto page Previous  1, 2
PostPosted: Fri Oct 05, 2012 5:18 pm    Post subject: Reply with quote
jonc wrote:
Maybe you could all check for beeps / buzzers:
Vincent 13034
Roger 13049
Harry 13059
059 should be a MY 1981 so should have them. 049 is late MY 1980 and 034 is May/June 1980.
Of course, buzzers could have been retrofitted to early cars. I bet plenty of them were back at works in their early years..
13034 is fitted whit a lot of buzzers, flat wires,boxes ...which I don't find on 13295.
Most doesn't work but we have to check the wiring when back from the bodyshop...
PostPosted: Sat Oct 06, 2012 9:00 pm    Post subject: Reply with quote
Just checked (again) to what beep in the video. Cool
007 (built somewhere in 1978)beeps, but not on all buttons, as is the case with 059.(09 oct 1980) cant recall from memory if both do it exactly the same Embarassed (057 is/was very out of order to check) Laughing
steelydave39
PostPosted: Fri Nov 16, 2012 2:25 am    Post subject: Reply with quote
My LED Lagonda did beep when any touch pad was pressed. I now have a CRT car. Does anyone have a CRT car with the voice warning feature working? It seems none of them do
PostPosted: Sat Nov 17, 2012 12:43 am    Post subject: Reply with quote
Did a 150-mile spin in 13385 today and the voice computer does work indeed although it is hardly audible. After a while, I could understand "oil pressure low" and more importantly "low fuel" repeated constantly until I refueled. Quite practical when the screens are either not working or showing wrong readings !
View user's profile Send private message AIM Address
PostPosted: Sat Nov 17, 2012 11:34 am    Post subject: Reply with quote
Dimitri,
If you can hear "Oil Pressure Low", I suggest that you get the oil pressure checked as soon as possible.
It may be that the sender is at fault (it is just an on/off switch for the CRT cars, grounding to earth when the oil pressure is low) or, it may not be the sender..............................
PostPosted: Sat Nov 17, 2012 1:56 pm    Post subject: Reply with quote
David, it's only done it once or twice in a sharp bend so will keep an "ear" on it in normal driving conditions...
Thanks for the advice anyway.
steelydave39
PostPosted: Mon Nov 19, 2012 9:46 am    Post subject: Reply with quote
Dimitri, Im having my CRT system completely restored. What is the full list of voice warnings, if you happen to know it? Also, do you hear anything when you press the "verify" button? Thanks
Page 2 of 2
